OEM vs Progressive front springs
All I can tell you is the change to Progressive fork springs was one of the best things I ever did to my FXRS. I did it after a car crunched my forks and I never realized how weak the OEM springs were. The bike feels much more planted and stable with much less front end dive during braking. Unfortunately, I immediately found out that it is also much more stable on the trailer with the front strapped down, since I found out the day after I rode it home from the shop that the accident had also trashed a lifter and I had to trailer it right back. The next winter I changed my rear shocks over to Progressive 412's and my bike rides and handles better with 137K on it than it did new.
As for which springs to use, go to the Progressive website or email or call them, they'll be glad to advise you. I used the standard length fork springs and 1/2" shorter rear shocks, but use a taller 140 tire in back to get my ground clearance back.
Thanks
Thanks for the info MP. I shall do the same. It seems only logical especially since my forks are apart. I was looking to see if there was actually a noticable difference between OEM and Progressive and if you say there is then the jury has reached a verdict. Especially since yours is the only reply I have gotten. Again, thank you
06WG, I put the standard height Progressive springs in my 07 FXDC and they basically eliminated front end dive when stopping. 11-1525 is the Progressive number, same for all 06 up Dynas.
The stock springs are 13 inches long and use an 11 inch spacer. Progressive uses a much shorter spacer and a longer spring to achieve the same overall length.
The ride is not harsh at all like I thought it might be. Very nice improvement and not expensive, I think I paid around $60.
I'm not a fatboy owner but I am a fatboy...
I had the progressive springs on my 06Ultra with the S/E 15wt fork oil in it and loved the way the front end felt...
I had read from many memebers here that they opted for the changing of the fluid only on there touring bikes and it made a world of difference...
When I bought my 09 Streetglide and had the chrome front end put on it I had the stock fluid changed to the S/E 15wt fluid and it helped...But the oval wasn't as positive as the actual changing of the springs...
So guess what is soon on the things to do...
as far as the rear shocks on a softail I can't help there except to say but two words...
Think Platnium
mandd71974
02-11-2016 09:51 AM
