Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Front axle gap?
Old 08-04-2018, 12:31 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,314 Likes on 1,861 Posts
Duplicate Post
Old 08-04-2018, 12:35 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by FXDL1450
Official manual.
That image applies to dual disc.
Mine is single disc.
It doesn't matter ... They are just going to greater lengths to insure rotor-to-caliper alignment because that is IMPORTANT.
The SAME WHEEL ... SAME AXLE ... SAME SPACERS (Left and Right) are used whether it's Single Disc or Dual Disc.
Do think that GAP will Change for that photo NOT to be representative of the Single Disc situation? ... The answer is NO
Right Now you can't see the "Forest through the Trees", which explains you earlier comments. (not meant to be offensive)
You just don't "Know Enough" yet
Old 08-04-2018, 12:55 PM
multihdrdr's Avatar
multihdrdr
Nothing wrong with Questioning things ... I do it all the time ... that's how one learns
But, the Point is that if one follows the Manual Step by Step, you would have some gap and it doesn't HAVE to be addressed because everything would have worked out fine.
One important thing that they list (in the correct order) whether single or dual disc ... Tigthen the Axle Nut BEFORE tightening (or final tightening) the Pinch Bolt / Nut
Old 08-04-2018, 01:31 PM
FXDL1450's Avatar
FXDL1450
FXDL1450 is offline
2nd Gear
The first reply to the OP seemed to imply loosening the main axle nut, set the gap, tighten the pinch bolt (which in the original case is a cap with two bolts) followed by tightening the axle nut. If that’s the case it’s not only backwards but dangerous advice.
Old 08-04-2018, 01:59 PM
multihdrdr's Avatar
multihdrdr
ok ... good work
(sometimes I don't pay much attention to the details of Bad Info posts... unless I really need to)
"Bad" Inaccurate info is the Nature of the Forum Beast
harley_jeff
01-20-2018 04:50 AM
anything2wheels
10-01-2016 09:13 PM
Ndoggct
10-07-2015 06:50 PM
texashillcountry
EVO
29
07-16-2014 07:35 AM
HDF Tech
12-12-2005 08:03 PM
Quick Reply: Front axle gap?
