Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Brake Pad - Life?
Old 04-11-2006 | 09:57 PM
2005UltraNC's Avatar
2005UltraNC
Default Brake Pad - Life?
What's the mileage expected on a bagger (05 Ultra) for front and rear brake pads? Thanks
Old 04-11-2006 | 11:20 PM
liltrk's Avatar
liltrk
Default RE: Brake Pad - Life?
TOTALLY depends on how you ride. Solo or two up? Lots of s$!t in the tour pack (no offence)? All over the brake or downshift to a stop?
I have 30,000 on mine. Changed the rear once, but I like to use the rear a lot. Fronts still look good.
Old 04-19-2006 | 05:28 PM
Neckball's Avatar
Neckball
Just replaced my rear tire yesterday, 15,013 miles. The pads looked a little thin. The manual says the minimum thickness is .040". Mine were at .100". I figured, what the hell, the wheel and caliper are off anyway, so I put in a new set. I measured the new pads just to have a reference, they were between .190-.195". I use more front brake than rear and don't ride very aggressively. Usually don't get into the rear brake much unless I'm riding 2-up.
Been a while since I've looked at the front, I'll check them this weekend.
Old 05-03-2006 | 11:51 PM
qvatch's Avatar
qvatch
6th Gear
I just replaced my rear pads at 25,600 miles. The inner pad was about two stops away from metal to metal. The outer pad was just a little bit thicker. I'd guess the fronts still have about 10k miles left on them but I'll replace them this coming winter if they don't need it before. I'd say I use my front and rears about the same amount. I suppose the extra rotor and pads on the front accounts for the less wear on them. I ride two up with alot of sh*t in the bags & tourpak about 95% of the time.
Old 05-25-2006 | 02:51 PM
sleepneagle's Avatar
sleepneagle
I replace mine when I do a tire change. 10k on rear, all brakes get new pads. Pads are cheap, life isn't!
Estil
10-15-2009 08:45 PM
hogsport
09-02-2008 10:13 PM
Navychief
10-01-2007 09:05 PM
anacharis
08-21-2007 10:59 AM
mark2004RK
08-10-2006 03:17 PM
Quick Reply: Brake Pad - Life?
