Fork Seal Tool ID
12-19-2008, 03:48 PM
Fork Seal Tool ID
Hey,
If you have the 41mm fork seal tool, could you post the I.D. please (02 Road King). An estimate of the tool ID, from the seal itself is 1.70" diameter. I dont have the forks apart yet. How close am I?
Tool OD 2.00 + .10 -.00?
12-19-2008, 05:02 PM
I don't use the tool or a piece of PVC. I use my fingers to push them most of the way. Then, I seat them using 2 wooden dowels 180 degrees from each other......I do it this way, because I don't pull the legs outta the trees.
12-19-2008, 05:05 PM
XXXFLHRCI is right PVC is the way to go Cheep and Easy to make. Good luck with your project.
12-20-2008, 09:55 AM
Thanks. I am using PVC and pulling the lowers off to install a Progressive lowering kit. ID anyone?
12-21-2008, 10:22 AM
Kbore, this site here shows you how to make a seal tool. You cut slits in the pipe so you can size it to your particular setup.
If you double click on the picture it enlarges it. The actual description of how to make it is near the bottom of the page.
http://www.motorcyclecruiser.com/tec...als/index.html
12-22-2008, 06:35 PM
Jimmers, we keep crossing paths! THanks, great article.
Baird
07-16-2017 12:18 PM
MartinSporti
2014-2023 Touring Models
03-13-2015 07:24 AM
Ridin'withTheKing
02-28-2011 06:46 AM
Kbore
12-27-2008 08:15 PM
thomasf59
09-04-2007 08:29 PM
2000 ,
41mm ,
davidson ,
diy ,
fork ,
harley ,
installer ,
king ,
kit ,
road ,
seal ,
seals ,
size ,
tool ,
tools
