tour pak on Ultra
Detachable Tour-Pak® Rack Kit
Transform your Electra Glide® Classic model for around town cruising. This kit includes everything needed to convert the rigid-mount Tour-Pak® to an easy on-and-off detachable version. In just seconds (and without tools), you can install the Tour-Pak® for that long run across the country, and remove it for a stripped-down look when you get there. With the addition of Docking Hardware Kit P/N 53803-06 (sold separately), you can install a detachable Sissy Bar Upright and passenger backrest pad for around-town passenger comfort. Complete kit includes two-up docking hardware kit, detachable two-up Tour-Pak® Rack, chrome license plate holder, reflector, and AM/FM antenna relocation hardware.
53303-07
Fits '97-'08 FLHTC models. '97-'05 models require separate purchase of Light Harness Kit P/N 70113-08.
MSRP US $329.95
53804-06
Two-Up Tour-Pak® or Two-Up Luggage Rack
Fits '97-'08 Touring models (except FLHTCUI, and '07-'08 FLHRSE3/4). Only reason it says NO to an ultra, is that HD does not encourage the quick detatch due to the amount of additional wiring required as it states "Quick Detatch"....
MSRP US $59.95
FWIW, You will have a lot of wiring to stow away under the Badlander seat..... Intercom harness, Rear speakers, CB Antenna and Tourpack wiring.... As you will be relocating the AM/FM antenna to the rear docking point (Not sure if that is in the kit.... can't remember...)
53303-07
MSRP US $329.95
53804-06
MSRP US $59.95
