Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
wider tire
Old 03-29-2006 | 03:35 PM
93 fatboy's Avatar
93 fatboy
Default wider tire
I have a 93 fatboy with a stock rear tire, I would like to put a 150 tire, is there a way to space the drive pulley and offset trans with out drastic changes
Old 03-29-2006 | 11:46 PM
tripl8's Avatar
tripl8
Default RE: wider tire
A 150 should "just " fit without any changes ..take a close look.
Old 03-30-2006 | 12:49 PM
BlueDeuce's Avatar
BlueDeuce
A buddy of mine just did this yesterday. It will fit. . Just turn those strut support mounting bolts around to give yourself the extra clearance in the fender well and put a cap nut on the outside. Do this with the rim off so you can get your torx bit inside the fender. It's tight but it'll work.
Old 03-30-2006 | 04:21 PM
93 fatboy's Avatar
93 fatboy
THX for the info, Ill give it a shot.
Old 03-31-2006 | 02:25 PM
93 fatboy's Avatar
93 fatboy
I tryed to put a 150 wide tire and it hits the belt. Is there any suggestions on how to get around this issue. []
Old 04-01-2006 | 07:50 PM
95BadBoy's Avatar
95BadBoy
Pully spacer. Check rear wheel alignment.
phr33d0m
06-28-2012 09:26 PM
stilup
10-23-2011 08:58 AM
FatBobBerry
04-14-2010 04:07 PM
Rowdy25
Wheels/Tires
08-05-2009 06:08 AM
SkyRider
06-10-2008 01:49 PM
Quick Reply: wider tire
