Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
90-90 21" tire
Old 09-03-2008 | 06:45 PM
GPHDXLC's Avatar
GPHDXLC
Default 90-90 21" tire
Buying a mag 21" wheel, was thinking of going to the Venom 90-90 size, only $5 more then Stock size. Stock tire size is 'Diameter' 27.20". Venom 27.60...'Width' stock 3.25".
Venom 3.70"... By my math my bike would set about 3/16" higher and the tire would be about 7/16" wider. With close to being 1/2" wider, I dont think the tire would look so skinny from the front. Anybody have one? pics? seen one on a Sportster?...Thanks.
Old 09-03-2008 | 07:08 PM
Lakerat's Avatar
Lakerat
I put a Venom 90/90-21 on the front of my FXR to replace an880ME 90/90-21 not knowing they weren't the same size. The little mold lines actually rubbed the sides of the fender til they wore off. Still sends graved between the fender and tire tread. I finally got used to the bigger looking tire and change in handling. I will go to the MH90-21 the next time.
Old 09-03-2008 | 09:05 PM
GPHDXLC's Avatar
GPHDXLC
'LaKerat'
I did know that the 880 are a bit smaller the Venoms. I dont know why they rubbed any place on the fender. On my 06-custom I have just over 1/2" clearance on each side at the closest points, a Venom should only be 1/4" wider on each side then my stock tire. Do you think your fender may be a bit closer to the wheel then a 06 custom. I wan't to be sure my tire dont rub. Sure dont look like it will...
Old 09-04-2008 | 12:19 AM
Fayston's Avatar
Fayston
Thumbs up
I went from a 19 to a 21 Avon Venom on my '88 FXR; fits well and I think it looks great, I'd recommend it. It sounds like you have a Sporty; because the Sporty is narrower I think it could look even better.
Old 09-04-2008 | 05:48 PM
Fayston's Avatar
Fayston
Default Pic of 21"
Here's a pic of a 21" wheel with a 90/90 Venom on my FXR.
Cbrwags
Wheels/Tires
09-07-2016 08:30 AM
fjoh
Wheels/Tires
01-16-2016 09:19 PM
JWKHD1
07-25-2012 09:54 AM
seven7
07-26-2007 08:36 PM
GPHDXLC
07-01-2007 12:25 AM
Quick Reply: 90-90 21" tire
