keeping handlebars from moving?!?!
07-22-2008, 06:37 PM
My springer bars want to move whenever I put the least bit of pressure on them. I was told that a coke can can be used as a shim . I tightened the allen bolts until I stripped one of the holes (thank god for helicoils). What are my options? Tightening does not work so I am assuming I need some sort of shim? Any suggestions? Things that worked for you?
07-22-2008, 10:39 PM
RE: keeping handlebars from moving?!?!
cmon..no one has any experience with this?
07-23-2008, 09:52 AM
get the bars at the height you want them and drill through the risers and put a stud in there
07-23-2008, 10:22 AM
Drill and doll pin from the inside of the risers so the drill holes do not show.
07-23-2008, 10:24 AM
take off top riser. drill blind hole. \\; insert pin. \\;mark bar and drill. \\; put top riser back on with pins going thru bars.
07-23-2008, 10:26 AM
It is really hard to post advice on this frigging site since anything over 2 lines long will not post! \\; WTF - why can't they get this crap fixed after several weeks????
07-23-2008, 10:32 PM
thanks for the advice. What kind of pin would you use?
07-24-2008, 01:42 AM
I was told the bushes were rubber to reduce vibration. Quite a bit of movement on my xbones
07-24-2008, 07:29 AM
I think the shim approach is the way to go
07-25-2008, 08:13 AM
well put in a roll pin and it pinches the wires so that is a no go. I think I am going to take the riser clamp and grind it down about an 1/8 inch to see if that will hold the bars better.
thebeginning
General Topics/Tech Tips
11-15-2013 09:46 AM
KYRyder
02-18-2013 12:12 AM
rlowride
08-27-2011 08:20 AM
The Donald
08-17-2010 12:39 AM
johnnyhumble
01-15-2008 08:51 AM
bar ,
bars ,
clamp ,
drill ,
handle ,
handlebar ,
handlebars ,
harley ,
hole ,
keeping ,
motorcycle ,
move ,
moving ,
riser ,
touring
