Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
tire pressure
Old 06-27-2008 | 07:48 AM
cznmike's Avatar
cznmike
Default tire pressure
I've got a 16" 200mm rear and 16" front tire. I've been told conflicting tire pressures from every tech at the dealership and everyone I meet. What should you run in them- I ride solo 98% of the time.
thanks
Old 06-27-2008 | 09:18 AM
pscheval's Avatar
pscheval
Default RE: tire pressure
check the owners manual, my 07 ultra says 40 in each
Old 06-27-2008 | 09:21 AM
cznmike's Avatar
cznmike
Checked that a long time ago. It's just that the techs disagree with the manual and each other on how much air to run.
Old 07-18-2008 | 05:10 AM
HDBassman's Avatar
HDBassman
6th Gear
What the manual say and what is stated on the side wall of the tire can be different. Mine is.
Old 07-18-2008 | 03:07 PM
madden23's Avatar
madden23
Agree look at load rating on tire and remember this is max for a heavy load not for a solo rider.(figure you should be a few psi under max) You can go to manufacturers website and that will also tell you. Whats in manual is for OEM tires only.
Sportstatler
11-18-2012 10:04 AM
mxz600
04-14-2009 09:26 PM
morjubet
01-27-2009 08:33 PM
mississippiboy
09-16-2008 11:47 AM
95hdtlk
EVO
12-27-2007 08:56 AM
Quick Reply: tire pressure
