Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Lowering Your Bike
Old 02-13-2006, 10:09 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Lowering Your Bike
We often talk about lowering the front and rear of motorcycles. The question usually goes "how much can I lower the rear (or front) of my Harley Davidson motorcycle?" There is no firm answer for this question. Rider weight, one or two up, packed for a trip, fender clearance and even how rough the local roads are can factor into your decision.
How does lowering affect handling? Again, it depends on how much you lower it. If you only lower it 1" you may only lose some ground clearance and add a slight amount of rake. If you lower it as far as you can or "Slam" it, you will most likely lose considerable ground clearance causing you to drag parts and pieces in turns and could even upset the bikes stability.
Deciding on if and how much to lower your Harley Davidson motorcycle is a personal decision. We advise considering all of the issues like fender clearance for the tire wiring and ground clearance along with the handling issues.
So, you decide to lower the bike, what do I look out for?
The best thing to do is to remove the rear wheel and make sure that all of the fender strut bolts are not protruding into the fender well. Adjust, shorten or modify any that do. A tire will rip itself apart on any thing it can hit up in there. Reroute and wires or bundles so that they are totally clear of the area on inside top of the fender. Many a wiring harness has been ripped up when the tire hit it.
Also, check the bolt that holds down your seat! Often this bolt is long enough to hit a tire when you lower the motorcycle.
We always check the full travel of the wheel and make sure it cannot rub or hit anything.
After you install your lowering kit or shorter shocks, make sure you set the spring load properly following the manufacturers instructions. By setting the preload to soft you may easily bottom and upset your handling.
How do you lower the front of your Harley Davidson motorcycle?
Most of the same decisions apply here. Riding style, weight, roads etc all are factors.
Make sure that the wheel has sufficient clearance to the fender and fork legs. Check brake cable and speedometer cable routing.
On fork lowering you can tune the forks reaction to bumps and braking by increasing or decreasing fork spring preload and oil viscosity and level.
Progressive Suspension, White Brothers and Race Tech make some outstanding products for lowering your bike. All are top notch and high quality. Race Tech has an innovative cartridge emulator that we are very impressed with. We will follow up with an article on this product soon
We caution our customers to consider all of the issues before radically lowering their suspension. We also highly suggest lowering the front and rear the same amount for most applications.
Source: Direct parts.com
Old 09-09-2008, 01:12 PM
peterj22's Avatar
peterj22
peterj22 is offline
Stage II
Default raising bike back up
I was given a used softail for Christmas with it already lowered with a White Broth's Front lowering kit. Looks like I have the 2 original springs in the box. What's the best way to raise it back up? Can I get any directions or diagrams?
Old 07-13-2010, 11:02 AM
scootadoc's Avatar
scootadoc
scootadoc is offline
Default Raising your bike
Have the same problem-no, nobody gave me the bike-but I need to RAISE my ride
The po was, by his own repeated comments, short...as in 5'8.
I admit I like to do some leaning, but the floorboard brackets are wearing thin.
Can't find a lowering kit on the bike, but he must have done something. Clearance is less than 4-1/2".
New fork springs? Crank up the rear shocks? I know it's important to maintain the f/r height ratio.
Glad to hear I'm not the only one with this problem.
What to do...
Old 07-13-2010, 11:06 AM
scootadoc's Avatar
scootadoc
Default Raising your ride
BTW-looked thru all the paperwork and there's no sign that front end was messed with.
SnoRider
12-27-2015 07:47 PM
Dailydriver06
11-19-2011 06:27 AM
Another Young Sinner
04-02-2011 05:51 AM
hogandfrog
06-22-2008 06:43 PM
AZJD
01-07-2008 02:20 PM
Quick Reply: Lowering Your Bike
