changing fork oil on 2000 fxdx
does anyone know the correct way to change fork oil on this bike? Is it easier than it looks? there are 3 different adjustments on each fork! any help will be greatly apreciated . thank you in advance. geno
[IMG]local://upfiles/7348/0537751262764CA799061F388583BD6A.jpg[/IMG]
RE: changing fork oil on 2000 fxdx
1- remove the lower drain plug from the lower legs ( oil pan under ofcourse)
2-remove the upper fork leg nuts
3- mesure the proper amount of oil for each side
4-replace the drain screws
5-use a small clean funnel and pour it down the hole
6- replace the upper fork nuts tourqe to specs
Viola your done
as for adjustment i dont where you see that
i would go to the s/e heavy fork oil btw
Viola your done
