front wheel applications
RE: front wheel applications
You would need to change the bearing in the 98 wheel to adapt it to a 00 Touring bike (3/4" to 1"). Next will be the rotors. If your going to run Twin Cam rotors on an EVO hub you will need the adapter ring (fill the difference in space)(2.208-1.986). Vulcan works makes some very nice wheel adapters to go either forward or backward in years.
Should you take on this project let me know and I can point you in the right direction to do this without headaches. Seen it, done it, been there before!
ORIGINAL: Puzzled
If you wish my advice, stay away from the <2000 wheels. Do another project with your money IMO.
will a front wheel off 98 touring bike fit on the 2000-up touring bikes without special modification?
3/4" Bagger FLT front axles 1984-1999
The REARs in 2000 were 3/4".
1980-1999 3/4" 411110-79A
2000-2001 3/4" 41110-89
2002-2007 1" 41056-02
2008 ? 41056-08
ORIGINAL: Puzzled
1" Bagger FLT front axles 2000-2007
2008 ? 41056-08
2008 ? 41056-08
ORIGINAL: FastHarley
Your 2001 FL does have a ¾” axle. [HERE]. If you have a 2000 & 2001 than they are ¾” sealed bearings. The rotor register is 2.23” on the fronts (new style) whereas the 1998 has a smaller register due to Timken Tapered bearings. A 2000- current wheel bearing housing is 52mm. On a side note, you can never put a 2000 & 2001 (3/4” axle wheel) onto a 2002 – current bike. The 1” axle bearing spacer can not fit inside of the wheel (00 &01). Hope this helps.
ORIGINAL: Puzzled
so, all these spoked wheelsfor sale onebaylist them for 86-99 harleys. They cannot be fab'd to fit on my 07 softail??? i want to go from a 21x2.15 to a 21x3.25 wheel. is there anywhere i can pick up this size without breaking the bank. ive been looking and i cant seem to find any at a reasonable price. any other options??
Again, that rotor register problem. 2nd, your axle is a 25mm (16 thousands less than 1” aprox.) Will a (1.225" wheel bearing axle spacer fit inside the wheel. You need these.) Buy the right hub. Who said you could not buy a late model hub (your finish choice), re-spoke with the spokes of your choice, than buy the correct rim of your choice? If you have a friend who knows how to lace a wheel, you are good.
loseranacummins
Wheels/Tires
14
12-03-2013 12:55 PM
