Withe the bike on the side stand, the forks are generally turned to the left. The right side of the wheel is most visible. It sort of hides the brake rotor, caliper, and lines, giving the front end a cleaner look.
ding ding ding Pistole got it right. whenever there is only one rotor on the front it will always be opposite the rear. This is ti insure brake balance.
ORIGINAL: pistole
- the front is 'opposed' to the rear.
So... you're saying the factory will choose function over form?
ORIGINAL: pistole
Really? Why do you suppose the Buell XB has both on the right side? Buell has arguably the most efficient single sided brake with the perimiter brake system. It is on the right side of the bike, as is the rear brake. Having ridden many Buells and many V-Rods with Buell wheel conversions, I can tell you first hand that when you stomp on these brakes, they do not pull to the right side AT ALL.
Anyone have any explination to this deviation from the theory?
