Replacing Rear Brake Line
2003 Spinger FXSTSI
I am in process of replacing front & rear factory brake lines with SS. Have the new SS lines on order but havent received them yet.
I removed the factory lines. Read some posts& did as instructed.
Question: When removing the rear line I detached the junction box & wiring, asinstructed on another post. What do I do with that box. Thefactory rear brake line is hardfastend throughit?
Sorry for being a newb. Great forum & thanks in advance!
RE: Replacing Rear Brake Line
Thanks for the reply.
I can see from the factory tee & pressure switch what you are saying.
Will my new Harley SS rear brake line have a T fitting built into it? It looks like the factory T& switch are bolted together. If the new line has a T built into it, I would unbolt the factory switch and bolt to the new T.
Otherwise, do I purchase a new T & splice the new SS rear line and connect to it?
Thanks
Thanks
I would almost guarantee it would since it would be pretty crazy for them to sell a kit that eliminates the rear brake light feature.It may just be two lines and you still might need a tee.They do tend to nickle and dime you.Either way you know what you need to do to make it work.
snacks63
05-18-2010 08:12 PM
mile hi
06-06-2007 12:13 PM
