Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Adjusting neck bearings
Old 12-19-2005, 12:58 AM
usblues101's Avatar
usblues101
usblues101 is offline
Default RE: Adjusting neck bearings
I am assuming since you greased it,you are done.Did you remove clutch cable and windshield,lift bike and turn wheel to left and release and count the swings?2?,3?,3 1/2?Thats the critical part.It would be hard to tighten stem nut too much.Did you loosen pinch bolts on both sides prior to tightening adjuster?Did you test ride it?Can't wait to do it again next week?Control yourself,your having toooo much fun.Think you did OK,Bob
JT-FXDL
07-14-2011 07:47 PM
HedgeHog77
09-25-2007 03:33 PM
Dancemax
10-10-2006 09:08 AM
bajabob
03-11-2006 07:10 PM
pococj
01-17-2005 07:23 PM
Quick Reply: Adjusting neck bearings
