front grease leak?
front grease leak?
Hello,
I have my sportster stored in a neighbors un heated garage. i went to check on it and i noticed grease coming out of the bottom of the handlebar stem. is it because of the cold? it was real cold for a while here in ny. Or is it problem?
thanks
[IMG]local://upfiles/6511/7B215076796744E19C655B316B2FAEC4.jpg[/IMG]
thanks
RE: front grease leak?
Looks like someone got a little too much grease in the steering head bearings. My Electra glide Classic does the same thing, it's just under the fairing where you can't see it.
It's not a problem, jsut wipe it off. It probably ozzed out because you have it in a heated garage and its not being used. The grease just got hot and liquified a little.
Regards,
Bill
Regards,
Bill
there is a problem if greese is not being pushed out of steering head. the steering head bearings are not sealed so moisture and grime will work its way in the only way to keep the steering clean is to purge the bearings. its a bit messy but your bearings will last.
Tim
It will still probably happen with the "special" grease too. The factory only coats the bearings and does not fill the neck. Once a service is done, it should fill the neck also and this is when the grease seeps out after it warms up either from riding or in hot temps.It'll stop after a ride or two.
heckfrozeover
05-25-2014 07:12 PM
