Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Removing glued on grip for reuse...
Old 10-24-2007, 02:34 PM
riles10's Avatar
riles10
riles10 is offline
Default RE: Removing glued on grip for reuse...
donk, not quite sure how the throttle boss works, how exactly does it rest your grip when riding?
Old 05-26-2008, 07:40 PM
jumpmasterjay's Avatar
jumpmasterjay
jumpmasterjay is offline
Anyone have any other ideas for removing ISO-grips?
Old 01-27-2010, 03:42 PM
Trikerjon's Avatar
Trikerjon
Trikerjon is offline
Arrow Removing stock rubber grips without cutting them
I just replaced the stock grips on my 2008 Road Glide. To remove the old ones I wrapped a piece of sandpaper around the grip, then used a pipe wrench to twist the grip left and right ,till the glue broke lose. The grip came off without destroying it. The right side was a piece of cake [Fly By Wire] Hope this helps you guys.
Old 01-27-2010, 03:47 PM
jimsflh's Avatar
jimsflh
jimsflh is offline
or if you can get a pick, or small screw driver wedged in, then spray some wd-40 or something in there, and work the "tool around and deeper spraying when needed.
hollandhunter
01-16-2017 11:35 AM
harpoon
10-18-2011 08:46 AM
SeniorChief56
07-19-2009 12:46 PM
Axeman71
08-11-2007 09:07 AM
harley0711
General Topics/Tech Tips
07-24-2006 05:22 PM
Quick Reply: Removing glued on grip for reuse...
