Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Lowering inverted front end
Old 10-08-2007 | 02:07 PM
Gigawitz's Avatar
Gigawitz
Default Lowering inverted front end
Hello, Has anyone here ever lowered an inverted front end? I have a stock length 58mm inverted front end from Midwest Cycle Supply (Ultima) is the brand. My 96 softail was lowered 2 inches front and rear before I bought it. It also had a 16" front wheel that I upgraded to 21". The bike is a little tall in the front for my taste and I would like to lower the front 1-2 inches. Anyone know if inverted front ends use the same springs as a wide glide? I am hoping I can take my springs out of my lowered WG front end and put them in the inverted? Thanks
Old 10-08-2007 | 09:28 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default RE: Lowering inverted front end
You are in California. Take them to GMD Computrack . Probably cost you more then them are worth, but check it out for yourself.
Old 10-11-2007 | 05:47 AM
Gigawitz's Avatar
Gigawitz
Nobody? Guess I'll have to tear it down and start measuring springs.
Old 11-17-2007 | 08:39 PM
ruff12's Avatar
ruff12
6th Gear
How did it go? I was curious a I wanted to lower my inverted front end as well...Have you ever heard of anyone cutting down the springs themselves?
Old 11-18-2007 | 02:53 AM
donk_316's Avatar
donk_316
Ultima? God only knows... But the HD Marchocchi Inverted Front End I can hook you up with the right people to have them tuned / lowered / whatever you want.
Sending my tubes out on monday
jgcable
01-17-2014 11:55 AM
Thewaxmania
05-01-2009 03:12 PM
assassin307
05-26-2008 06:29 PM
TheeBoy
01-16-2008 02:46 AM
SoFlchef
01-08-2008 09:30 PM
Quick Reply: Lowering inverted front end
