Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
07 RK rear wheel removal
Old 09-27-2007 | 07:04 AM
52wrench's Avatar
52wrench
Default 07 RK rear wheel removal
9700 miles and time for a new rear skin. I'll remove the rear wheel myself and have the shop put on the tire. Got a dumb question. Once I get it up on the center lift, remove lower shock bolts and get the axle outwill the wheelslip out between the fender and muffler? Yeah, I got a shop manual, just looking for a way around removing the slip-on. Thanks.
Old 09-27-2007 | 11:21 AM
fxstcguy98's Avatar
fxstcguy98
Default RE: 07 RK rear wheel removal
If you can get the axle out without removing the slipon, the tire will drop straight down and go under the fender. I don't have an 07, but I don't think you can get the axle out without removing the slipon.
Old 09-27-2007 | 11:42 AM
52wrench's Avatar
52wrench
Thanks. Yeah, I looked at it this morning, looks like the bike has to be high enough so it will go out under the fender. Some other bikes I had it would slip out between the swing arm and fender with it on the center stand.. What do guys do who have to pull the rear wheel off on the road to patch a tube, lay the bike over on the crash bars? Think I'll put the new cush drive system on it while I've got it out. I don't have a major problem with drive noise but it's got to help.
Old 02-08-2008 | 05:10 PM
superglide317's Avatar
superglide317
I don't see how to get the axle out without taking your muffler off-Don't short cut the allmighty manual-it's written to help us out
buzzardgame
04-06-2009 05:35 PM
ckamin
Wheels/Tires
01-21-2009 04:13 PM
sniper77
12-01-2008 06:03 PM
crocker
04-18-2008 02:15 PM
thomasf59
06-12-2007 07:36 PM
Quick Reply: 07 RK rear wheel removal
