Vaccum bleeding ABS brakes
I use a standard automotive vacuum bleed tool I bought from Amazon. Did it twice so far without any problem, the only precaution I do is using help by some of the family to keep the reservoir at level all the time in order to avoid any air to get in.
I use the same tool to bleed the hyd clutch as well.
The vacuum tool does not bleed the ABS module, for that you need either the dealer’s DT or an equivalent after market one.
https://shop.snapon.com/product/Vacu...Bleeder/BB9008
twoglides13 (01-29-2021)
you need a tool to pulse the abs module but it bleeds just fine. never seen on on a mc but older abs system had two brake fluid reservoir as it was a stand off system. the hd system is all about volume controlled by piston chambers in the module, the reason you have to hold constant pressure with the brake control, as the module pulses, it removes or adds space, aka, volume but in static form, the fluid just passes through.
