Fork Noise
RE: Fork Noise
ORIGINAL: wesd41
Yeah- ask the guy just what exactly is supposed to be"breaking in"??
There is nothing to "break in".
The noise could be the springs or spacers rubbing againest the tubes, dampner rods are loose orchrome got inside the fork legs.
Also check to see if the fork covers are rubbing if the bike has them.
RE: Fork Noise
Don't worry about the innards, chrome won't throw down into the tubes (unless you put auxilary anodes in there, which would be stupid), copper maybe the first couple of inches and a little less with the nickel. In any case, you are talking about microns of thickness that wouldn't effect the fork fittment. Maybe he put the fork seals in upside down or didn't get the snap ring installed properly. It shouldn't be making noises just because the lowers were changed out.
