RT switch housing loose
Looking for some thoughts. I have a 16 Road King. I just put 12 KST bars on it and the right switch housing (front) broke where the bolt goes in. I ordered a new one and just installed it but the whole housing is loose - moves up and down around the bar 1/8 to 1/4. Nothing else is broken or damaged and everything is tight. I cant for the life of me figure out why. I did the bars myself and have done grips multiple times. No idea. Anyone ever seen this?
Crotonrz thank you for the reply. All that lined up. I ended up wrapping the bar in that same area with double sided tape and that did the trick. The bars are perfect and very well made, it was a mystery. It was almost as though the bar was slightly thinner than stock by a hair but they are not because everything else fits. Thanks again.
Crotonrz (07-10-2020)
I agree something was weird. But it’s just the switch cover and was seated correctly, just spun a little bit. Everything else on the bars are perfect. It’s tight now. When I get the energy and temperament to take it apart 17 more times I’ll go back in and look again. I am mechanically inclined, this one just got me
Is it possible there is a cable pinched in the housing? I have KST bars on three bikes, and never ran into an issue like that. If the housing was slightly loose on the bars, that would be one thing. But with 1/8 - 1/4" difference, that is something else. That is a lot of difference between the bar and housing.
Maybe I didn’t explain it very well. There’s no gap anywhere. The housing sits perfectly flush around the bars. It just spins around the bar up and down 1/8” or so. In other words it moves a little if I push the turn signal. Like it won’t tighten. Just a thin piece of tape around the bar on the inside edge fixed it. I was sure I did something wrong as the parts are all new but I couldn’t figure it out
