Front fork rebuild Cost
Looking at the maintenance requirements and see that the front forks should be rebuilt at 50,000 miles. I currently have 46,475 miles on my forks, but am getting ready to go to Alaska next summer. So I want them rebuilt during the off season.
I removed both fork tubes and plan to take them in to the dealer. Has anyone had it done and what "should" it cost me to get both rebuilt, new fluid??
2015 Limited
2015 Limited
I haven't had this type of work done, but I am able to take a guess
According to HD Job times, I see:
1. Service or replace fork slider and/or seal – includes both sides removal, disassembly, cleaning, inspection, replacing parts, servicing damper tube, replacing bushings, assembly and installation = 2.9 hours
2. Replace fork side, both sides = 1.5 hours
So based upon you removing both fork tubes, it should be about 1.4 hours of labor, plus parts, shop charges, disposal fee, convenience fee (remember all this is just a guess)
If you went to the trouble of pulling all that off, you can rebuild them. Need an impact to break that lower bolt up thru there. Be interested in what those bearing sleeves look like. Mine has 50K on it. I can tell no difference from new. And if it is not filming the slider to the point of making a drip, not sure why you pulled it down. Those sleeves run in that oil and rarely wear.
I wouldn't be shocked that the dampener bolt comes out with a standard allen wrench. I've done several rebuilds and haven't had an issue removing yet. As for seating seal, spilt a piece of 2" PVC and gentlely tap seal in place using one of the old dampener washers to protect seal. When you completely disassemble be sure to clean all parts prior to re-assembly. I use Amsoil Shock Therapy #10 measured to amount listed for the particlular bike. Have confidence you can do it!
As I have been taught, PPPPPPP, or something like that.
