Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Dunlop D401 & K591 air pressure?
Old 10-12-2005 | 08:54 AM
TowJam's Avatar
TowJam
Default Dunlop D401 & K591 air pressure?
My FXDCI came with Dunlop D401F and K591 tires front/rear respectively. My dealer had them inflated to the max pressure of 41lbs and 42lbs but I backed 'em both off to 38lbs for the time being to take some of the harshness off the ride. What is the actual sweet spot for these tires? (I ride solo at 185lbs.)
Whay say ye?
Old 10-12-2005 | 10:57 AM
huffhuff's Avatar
huffhuff
Default RE: Dunlop D401 & K591 air pressure?
my manual says 36 front and rear. i add up to 38 rear when carrying a passenger but i .have an MU85 that has more load capacity than MT90.
Old 10-12-2005 | 11:26 AM
HDF Tech's Avatar
HDF Tech
The 41 lbs is MAX pressure ,not running pressure. The 16 inch rears use 36-38 lbs and the 19 & 21 inch fronts run 30 lbs.
Old 10-12-2005 | 12:25 PM
TowJam's Avatar
TowJam
ORIGINAL: TCSTD
Thanks! That's pretty much what I thought - and in fact, I think that's originally what they were at when I took it in Monday to have the wheels balanced. The first thing the tech did was try to tell me that the reason the front end was shimmying was because "your front tire is about 10lbs underinflated" and he then proceeded to pump it back up to 41lbs. Go figure.
On a side note... Unless I'm missing something, the '06 owners manual does not have tire pressure information.
Old 03-29-2006 | 09:58 AM
cardin4l's Avatar
cardin4l
6th Gear
Tyre Pressure data for 06 Dynas is at the front of the manual. In the spec section. One of the tables.
Old 06-05-2017 | 06:34 PM
fafcpa's Avatar
fafcpa
My tires are a D401F 100/90-19 in the front and a D401 160/70B-17 in the rear on an '08 Street Bob. Tires are inflated to 30 in front and 36 in rear. The front should be ok, but is the rear ok?
Thanks for your help.
Old 06-07-2017 | 03:00 PM
grbrown's Avatar
grbrown
Wink
Check your owners manual, as mentioned above. If you don't have one you may find you can download one on the H-D website - go to the Owners tab.
Old 06-07-2017 | 03:06 PM
fafcpa's Avatar
fafcpa
gr, that is the pressure suggested in the owner's manual both front and rear. But my rear tire is not a K591. Does that make a difference?
Old 06-07-2017 | 03:17 PM
grbrown's Avatar
grbrown
Wink
I think you will find that all Dunlop tyres for your Harley use the same pressures as in your manual. In fact many other brands do as well. The only alternative source of info is to check the Dunlop website. The K591 comes up as one of their tyres they recommend for Harleys. Looks as if they recommend 40psi for the rear, but check for yourself.
DCrider132
08-05-2019 07:46 AM
jaknb
07-17-2017 03:33 PM
cajun1957a
11-28-2016 05:24 PM
Ramez
02-24-2011 07:00 PM
RMT
08-08-2008 02:10 PM
Quick Reply: Dunlop D401 & K591 air pressure?
