cant seem to get to the snap ring on 41mm fork sliders
RE: cant seem to get to the snap ring on 41mm fork sliders
no its just a hole.. clean to the slider...(not a setscrew at all)
ah I said f' it ... put some soft rubber grips in my vice, and a shop towel, clamped the fork lowers and took a mallet and a pretty good sized punch and tapped it a bit on the hole.. it budged
so it lifted a bit off the lower, so I took a big flathead screwdriver and with just a little pressure twisted it to pry it up more and more.. little by little and it came off.
the snap ring was easy to get off and then i popped the lowers off...cleaned it up a bit and put it sorta together...
my 2inch PVC pipe even tho I cut it wasn't allowing me to seat the seal so..and its kinda late ill finish up tomorrow.
yeah I have it gaped and used one of them screw clamps to shrink it but I am not doing it right I guess to get seal down.. or i am taking it to easy on it :P
two pics are the sliders and one pic is my CUSTOM hehe waterproof (LOL) quick disconnect for my headlamp assembly that I put together so if I needed too instead of unplugging the thing under the tank and running though, I just unplug it there besides I hooked my garage door connections there as well..so was spliced there anyhoo..just fixed it up
[IMG]local://upfiles/26427/A55E8C3C2E254AE7AD93548146D76BDE.jpg[/IMG]
[IMG]local://upfiles/26427/438658AD1B6C4A55920EB301CDEB6F36.jpg[/IMG]
[IMG]local://upfiles/26427/A09F71081B334C10A2DE82C5744BC497.jpg[/IMG]
friknjok
01-13-2008 02:26 PM
