Installing Dual Brembos on an older Dyna...
True, DOT5 will swell any organic seals and overtime, well... my intention is to run DOT4 fluid in this system to preserve the Brembo Caliper seals - much easier to swap out the M/C piston seals if they fail.
My thread update - finally:
Completed this project in spring 2017 - all components installed perfectly but had to upgrade to progressive springs and 20wt oil to eliminate excessive nose dive . The only issue that I encountered was having to use the stock anchor screws (45405-75A) to secure the FXDXT lowers to the FXD stock slider tubes because the FXDXT screws (45399-96) are hollow to permit fluid flow adjustment and would compromise performance - I also haven't been able to locate a DOT4 label for the reservoir lid but that's OK :-) Total expenditure $882.00 not including my labor.
JayStronghawk (03-09-2019)
Yeah, I was afraid of that. That's really not for your FXD. That 46079-04 is for the FXDX adjustable forks.
You have to be able to "read between the lines" to get the correct one for a 2004-05 Dyna because they really didn't make a Dual disc model other than the FXDX (in the U.S. anyway, dunno about other countries).
Can you cancel or return your order? I can get you on the right path if needed
I think one thing to note is that the DX forks use a 10mm bolt to secure a cartridge damper inside the fork. The FXDs use only a 8mm bolt to secure the damping rod. You might want to make a sleeve.. The external plug on a DX is compression damping valve. You can simply plug the hole..
