Installing Dual Brembos on an older Dyna...
I have to retract this statement cause it's wrong - I actually discovered that the screw that this sentence was referring too is actually the same SKU# (45405-75A) between 2004 and 2005 and maybe more - my bad :-/
I'm not ready to take the front end apart until the rest of the parts arrive but I'm anxious to see the difference too. We have only one shop here that specializes in FXDX-T series - I'll take the lower into them and see if they can offer any input but they'd always be more inclined to take my money:-[
I found some 11.8" touring rotors from a 2012 FLHX courtesy of y22c which will match the caliper/pad clearance as you recommended - they should arrive late in the month. Other than that, all the other bits and pieces are accounted for, hopefully.
Well, Brembos are back on now as I found a sweet pair of 11.8" Floating Rotors (44943-08) on Ebay for $141 USD - they have recessed holes to accept the standard bolt head (3655A) so I won't have any clearance issues. I'm going to run DOT4 as the Brembo's are spec'd for it. I'm confident the Touring Master Cylinder, although labelled DOT5 will have no issues with it considering it's brand new. Only waiting on 2 more items from the dealer and off to the shop she goes.
Brembos...That's a better path
But please change the ID label on the Master, when you can Those details separate the hack jobs
Another Option: Weren't the Brembos New-Never Used? If so, remember you could run DOT5 (considerations...bike's a DOT5 bike, master is already labeled DOT5...)
Spring is nearing so the project is back on... Bike is stripped preparing for new rubber and front end modes including paint. Both Fork lowers needed to be swapped out with part # 46079-04 and 46078-04 as predicted by multihdrdr as the lower half of the internals are different. Was able to use stock bolt 45405-75A to secure dampers. Will install the stock springs with Lucas Synth 20wt to firm up ride. Front reservoir was upgraded to 11/16th Bore as required. Once the paint is done it will be ready for assembly.
I've posted my take-offs under CL here and can provide USPS delivery from Washington State.
Well, that's not my intention but I've heard that that will be possible with this configuration.
