Lineally Wound Springs VS Progressive
Conventional "straight wound" springs have a more or less linear force as they are compressed. Say you compress it 1 inch and get 10 pounds force, compress it two inches you get 20 pounds force.
Progressive wound springs (progressive rate) if you compress it 1 inch and get 10 pounds, compress it 2 inches you might get 25 pounds, 3 inches 50 pounds, etc.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
What progressively wound springs attempt to do is make up for lack of travel. In a perfect world, say in the rear.... you'd have 12" of travel. In reality you probably have 2-3. The prog wound springs try to be light over the smaller bumps, & still soak up the big ones. The job is better solved by valving inside the shock, but that's not typically found except in the top level units.
An interesting side note... constant would springs do not have linear rates. One of the things that determines spring rate is number of active coils..... the less the number, the stiffer the spring all else equal. As the spring compresses towards solid, the coils towards the ends start to touch each other, reducing the number of "active" coils, and the spring rate goes up.
It's a good practice not to design a spring to work in the first or last 20% of it's travel if spring force is critical.
Yeah, I know.... it's just a spring lol.
Progressive-rate springs are a compromise IMHO, used as a one-size fits all. The open-wound portion will compress readily, until fully compressed, when the tight-wound portion comes into play, compressing at a more resistant rate. They cannot provide the same uniformity of travel as single-rate springs.
If you are tempted to change your fork springs, Race Tech have a calculator to check the correct rate to purchase.
I can't see any benefit of using two springs, especially when the main one is a progressive-wound one. IMHO you will be better off using a single-rate spring matched to your weight, such as Race Tech. There was a time when engines used two or even three valve springs, per valve, to control valve bounce, but technology and metallurgy has moved on a lot since those days. For our forks a single spring is all we need and also all that the top suspension brands use.
chromedome
10-03-2009 09:20 AM
