Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Can DOT 4 fluid damage my brake system ?
Old 05-03-2007, 04:14 AM
sbkjo's Avatar
sbkjo
sbkjo is offline
Default Can DOT 4 fluid damage my brake system ?
The official dealer didn't notice,when renewing fluid, that the previous fluid was DOT 4 (i just bought a used RK). As DOT 4 and DOT 5 don't mixed, the system didn't work well.
Not satisfied i went to a Suzuki dealer who find out where was the problem. The point is he cleaned the whole system and then used DOT 4 fluid.
The system is now working well, but can DOT 4 fluid damage my system or cause any problem as HD standart is DOT5 ?
Thanks
sbkjo
Old 05-03-2007, 01:21 PM
07SG's Avatar
07SG
07SG is offline
Default RE: Can DOT 4 fluid damage my brake system ?
What bike do you have? The HD standard has changed from DOT 5 to DOT 4, beginning in I believe 2005.
Old 05-03-2007, 02:01 PM
fatboylust's Avatar
fatboylust
fatboylust is offline
According to HD's web page this is the fitment data:
DOT 5 Brake Fluid
Fits all models (except '05-later Touring models, '06-later VRSC™, Dyna™, Softail® and '07 Sportster® models).
DOT 4 Brake Fluid
Fits '05-later Touring and '06-later VRSC™, Dyna™ and Softail® and '07 Sportster® models.
either should work so long as they are not mixed and if one changes from one to the other then the system and internal parts must be cleaned to prevent cross contamination.
FBL
Old 05-03-2007, 04:30 PM
sbkjo's Avatar
sbkjo
sbkjo is offline
I have a 2001 RK classic.
Old 05-04-2007, 03:06 PM
JakeSabre's Avatar
JakeSabre
JakeSabre is offline
DOT 4, like DOT 3 and DOT 5.1, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Fluids such as DOT 4 are hygroscopic and will absorb water from the atmosphere. This degrades the fluid's performance by drastically reducing its boiling point. In a passenger car this is not much of an issue, but can be of serious concerns in racecars or motorcycles.
Old 03-12-2008, 08:41 AM
rayfinseats's Avatar
rayfinseats
rayfinseats is offline
DOT 4 brake fluid is NOT compatable with DOT 5 systems. It will probably ruin the whole brake system, seals etc. Plus, DOT 4 EATS PAINT andDOT 5 is much safer for paint. I have DOT 4 from the factory and I hate the paint factor. I wish they would have stuck with DOT 5 on the newer bikes. I don't get why they changed.
Old 03-13-2008, 10:21 PM
wydopn231's Avatar
wydopn231
wydopn231 is offline
My 2006 RKc came with dot 4 ,when installing new front master cylinder I changed it to dot5,for sake of my paint.No problems with system
Old 03-14-2008, 01:30 PM
bobcowan's Avatar
bobcowan
bobcowan is offline
The answer is no, it won't hurt your brake parts. Once it's been thoroughly cleaned and flushed, it won't matter. DoT4 is plenty good enough for a street bike. I use it in my track car without any issues, but I bleed it 6-10 times a year.
But I would flush every month or so to make sure there's no residual. No scientific data to back that up; it would just make me feel better.
Old 03-22-2008, 12:14 AM
PolarBear62's Avatar
PolarBear62
PolarBear62 is offline
My '06 Heritage came with DOT4,.... I just did some work on the bike and for kicks bled front and rear using DOT4 from Oreilley Auto Parts (Gunk/solder seal); good stuff. works fine. manual says DOT4,..good enough for me.
Old 03-22-2008, 12:48 AM
Jumpman's Avatar
Jumpman
Jumpman is offline
Sorta on this same topic.
We are getting ready to swap the front calipers on my Pops Ultra Classic to th new 2k8 Brembo's.
In the process of moving from DOT-5, to the now favored DOT-4... What are you suggestions for getting the system totally flushed of the DOT-5?
I don't ming re-building the master cylinder, but I don't want to leave any old DOT-5 in the lines...
Suggestions?
Quick Reply: Can DOT 4 fluid damage my brake system ?
