Wide Glide front end
Im building a 1200 bobber and have a wide glide front end on it. It came off a 2004 Night Train. I have a 21 inch wide glide wheel that is from a 99 WG. Timkin bearings. My question is can I use this wheel with the 2004 front end or will i run into problems with the rotor not lining up with the brake caliper or the wheel not centering with the forks. Thank you.
