ADJUST SHOCKS ON HD HERTAGE SOFTAIL
HAS ANYONE TRYED TO ADJUST THE SHOCKS ON THE SOFTAIL HERTAGE. I AM GOING ON A SADDLE SORE 1000 AND I AM TRYING TO SOFTEN UP THE RIDE. I GOT THE LOCK NUT LOOSE, BUT WHEN I TRY TO SPIN THE ADJUSTINGRINGWITH THE SPECIAL WRENCH,THE ENTIRE OUTER SHELL ROTATES ALONG WITH THE SHAFT THAT THE LOCKING NUT IS ON. HAS ANYONE ELSE HAVE THIS PROBLEM AND IF SO HOW DID YOU FIX THE PROBLEM
in my experience with the adjustable shocks on my 92 and 99 fat bot the shock shell is supposed to spin this is how the screw is allowed to either get longer or shorter. if you adjust the shock do it without the bike on the lift, this makes it easier to rotate the shock therefore you will not bend your wrench
