Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Grips
Old 01-18-2005, 09:13 PM
Road Nazi's Avatar
Road Nazi
Road Nazi is offline
3rd Gear
Default RE: Grips
just be careful to not drop the little brass fitting on the throttle side that holds your cables in place....I seem to drop everything at least once....
Old 01-19-2005, 11:39 AM
12Stones's Avatar
12Stones
12Stones is offline
Default RE: Grips
I just installed heated grips on my sportster.
After a ride this weekend, I'm thinking about doing the same thing.
Old 01-19-2005, 04:30 PM
pilot1996's Avatar
pilot1996
pilot1996 is offline
Default RE: Grips
I just went through this, I made post in this forum a little further down...
On my EG, I needed to remove the switch housing, this allowed me to get the grips underneath the housing and clamp it over the end of the grips. Moving the house will keep you from needing to saw off the end of your handlebar...if I understand the problem from above.
When you get to the throttle cable, you will need to loosen it by turning the adjustment nut further down the cable. When it's loose enough, you will be able to put it in place without breaking the plastic tit on the handgrip, and without fraying the cable. Once you get it all put back together, roll the throttle off and on (bike off) adjusting that nut until the throttle snaps back into place.
Not a tough job, just apply the standard rule, and allow 2 1/2 times as much time as you think you're going to need.
Mac
Old 01-19-2005, 07:28 PM
12Stones's Avatar
12Stones
12Stones is offline
Default RE: Grips
That's the standard rule? That sux.
Old 08-17-2006, 09:58 PM
Dancemax's Avatar
Dancemax
Dancemax is offline
Default RE: Grips
Justonemore, share with us your frustration with the wiring for heated grips.I plan to install heated grips on my 2003 heritage softail. I feel comfortable with the grip part but I am nervous about electrical. any help will be greatly appreciated. Need comments from other people about virtues (or none) of heated grips an cool weather...thanks
Old 08-23-2006, 06:48 PM
larry5h's Avatar
larry5h
larry5h is offline
Default RE: Grips
I had a previous bike with heated grips and loved them. They were on the bike when I bought it so I dont know about installation. Can't seem to get a response on this forum about heated grips.
kngpn
08-20-2015 05:21 PM
Rnt77
06-11-2013 08:47 AM
C.H.L.
05-02-2012 08:57 AM
pheur
08-10-2011 01:58 PM
toby34
05-04-2007 01:43 AM
Quick Reply: Grips
