No paragraphs ###Issue solved 2011-09-17###
Mr Wizard-Firefox 6.0.2 and it says it's up to date. Zap-It doesn't do anything when I hit the shift key. When I hit enter two times the text drops down and there is a space between the two paragraphs. When I hit "submit reply" it gets posted to the forum and there are no spaces between the paragraphs. It worked before but now it's not working. It's like the forum is taking may post and rearranging it with no spaces. Crazy! Thanks guys
I changed some settings for HDForums.
This is a test.
This is a test.
Looks like it's working.
I changed the editing mode under "edit options"/"miscellaneous options". I also reset something in there that said "restore default settings".
Thanks for the input and help.
This is a test.
This is a test.
Interface settings should look like this:
I will close this issue right now.
