When using the mobile version there is no Sig pic. You will also see none, or avatars either. So what? That's just the way it is. You can use the full version on your phone, but it is much slower.
That's what I thought and why I went full to test for OP . This way the option is there just as I thought it would be. My phone is fast enough when running on 4G I'm normally on full anyhow , but do jump to Mobile.
not seeing the images on the mobile app is fine, that's not my question. When you make a post the signature is appended automatically, and is there when you view the thread with a full version.
I should be there. So all the posts are the same, regardless if they came from a mobile or full version. Why not?
Can you try it from the mobile theme? See if you can reproduce the issue.
