Sig pic not showing up in my posts???
Old 09-17-2010, 12:59 AM
honkylips's Avatar
honkylips
honkylips is offline
Default Sig pic not showing up in my posts???
My user CP shows a sig pic for me, but it doesn't show up in my posts? Any idea what the issue could be?
Old 09-17-2010, 07:58 AM
hotshoe's Avatar
hotshoe
hotshoe is offline
I have the same situation and I do not know the answer.
Old 09-17-2010, 08:09 AM
hspring03's Avatar
hspring03
hspring03 is offline
Check the size of the picture..... most likely it is too big.
The limitations are posted around here somewhere
Old 10-05-2010, 08:37 AM
flyingj's Avatar
flyingj
flyingj is offline
I'm having the same problem with the signature picture. I'm also having trouble viewing attachments within threads, I've met the required number of post's any idea's/help is appreciated.
Old 10-05-2010, 08:47 AM
hspring03's Avatar
hspring03
Number of posts.....yes..
But not the required amount of time.... Must be registered at least 5 days.
Old 10-05-2010, 08:54 AM
flyingj's Avatar
flyingj
flyingj is offline
Do I have to be a member for 5 day's for the signature pic as well? If so I should be good tomorrow then.
Old 10-05-2010, 09:39 AM
hspring03's Avatar
hspring03
Not sure about the sig.... Make sure you check the size of the picture your trying to use.... And also read this post from Terry about sigs.
Originally Posted by Terry1955
Make Sure you have gone to your "USER CP" (blue bar,left side at the top of the forum) and then click on "Edit Options" and scroll all the way to the bottom and use the drop down to change from "Basic Editor" to "Standard Editor." This will allow you to "Insert" your photo into your Sig.
While you are in "Edit Options" you can change your time and change the Forum Defaults so you can see more threads and posts. You can also click on the box to allow the PM system to notify you when you have a new pm (pop up).
Terry
Old 10-05-2010, 08:52 PM
flyingj's Avatar
flyingj
flyingj is offline
Hey thanks I finally got it too work thanks for all of your help.
Old 02-01-2011, 02:29 PM
DYJ's Avatar
DYJ
DYJ is offline
ok... so I know my picture is small enough and I have changed to enhanced on my "Edit Options" .... and yet, the sig picture is still smarter than me!! What am I doin wring here?!?!?!
at least I got the avatar picture down
Old 02-02-2011, 02:23 PM
OldBoldPilot's Avatar
OldBoldPilot
OldBoldPilot is offline
Veteran: Marine Corp
Received 24,107 Likes on 5,313 Posts
Same issue. Sig picture worked fine for a long time, now all of a sudden it doesn't. Any explanation?
Quick Reply: Sig pic not showing up in my posts???
