I have read the the HOW TO,,,,but do not see the "Embed Picture In Post" box to put a check mark in. If I use photo bucket,,the posts are very small...any help is appreciated.
when you copy your picture from photo bucket, paste it in the window that you type your text in. You will notice the IMG in paranthesis before and after the URL is in upper case. Change them both to lower case and it will work.
When you upload to photobucket there are 4 choices of code below your pic. The bottom one is called "IMG code."
Copy that IMG code and paste it right into the message, with your cursor blinking right where you want the pic.
That does it. Like this:
I appreciate all the help, and understand how to use the IMG code from Photo Bucket. The Photo Bucket images are so small.....let me try one with IMG Code.
