Should I replace these gears?
Tackling a 45 3-bolt tranny for the first time.
I don't know how well it worked before disassembly, so I don't know what to fix.
Pictures below are for 1st and second gears. No missing teeth, but certainly showing some wear from their respective clutch gears.
Should I replace them 'while I'm in there'?
Leaning toward replacing second gear for sure, as it would get the most use and is the one you need to find reliably!
first
second
first
second
Received 5,424 Likes
while I know the guy is trying to help with the Andrews gear set - but they do not make 45 parts at all nothing
in your search the real guys who are selling are listing those gears with the original part numbers -- and not 45 trans gears kind of thing
BUT your parts book could have the 1920s parts numbers that are 5 numbers and not 7 numbers sometimes a gear or two will show up but - 35275-41 is one of the gears - main shift first gear this is the number you need to chase those parts
Some listings from the Bay, maybe one of these will help you out:
https://www.ebay.com/itm/WL-WLA-Serv...IAAOSw7MNeg7f3
https://www.ebay.com/itm/GENUINE-Har...ss!11755!US!-1
https://www.ebay.com/itm/Harley-Flathead-45-WLA-WL-Counter-Shaft-Sprocket-Nos-Oem-WLD-WWII-2035-41-Gear/193470660300?epid=1522964784&hash=item2d0bbffecc:g 8UAAOSwlndZFLXO
https://www.ebay.com/itm/GENUINE-Har...pe!11755!US!-1
Architect (05-19-2020)
