Sponsored by: Jekill and Hyde
cold and jetting probs?
Old 04-07-2007, 10:41 PM
Garett's Avatar
Garett
Garett is offline
Default cold and jetting probs?
i got my bike back today from the stealership, i got the 5 k service done and a 42 mil mikuni carb installed, i started riding the bike home ,35 milesto home got 5 miles noticed the choke was left on, so i turned it off, then at all stop lights and signs , it acted like it wanted to die on me, the idle was set to low !! but also once in awhile it was puking through the carb a lil , now keep in mind it was 29 degrees here , which i froze bike never got over 160 temp and the idle was set to low , could this cause it before i call them back ? because if i do call them back we gonna fight , they have messed up bike everytime its been there !!! today light scrathes all over bike , they rubbed most out , only in the clear but still makes me angry!!! i need a good place here in northern IL, but paint is a easy fix , would the cold and low idle make this puke a lil?
Old 04-08-2007, 09:00 AM
Road_Clam's Avatar
Road_Clam
Road_Clam is offline
Default RE: cold and jetting probs?
ORIGINAL: Garett
Explain "puke". Long story short, very cold temps cause your engine to run very lean, further aggravating this occurance is the fact that Harley has to push the factory jetting so lean to pass strict mandated EPA guidlines. Leaving your choke on too long might have partially fouled your plugs. Throw up some more specific details.
Old 04-08-2007, 10:05 AM
Garett's Avatar
Garett
Garett is offline
it made a weird noise, hard to explain like it sounded like it was comming from the carb , backfiring , not through the exhaust,
Old 04-08-2007, 08:13 PM
murphdog's Avatar
murphdog
murphdog is offline
Probably as simple as adjusting the idle mixture screw properly. What you're describing sounds like classic leanidle. The mixture screw on a Mikuni is an air adjustment, in is richer out is leaner. This is opposite on the Kehin, the screw is a fuel adjustment and in is lean out is rich. You need to find out how the dealer set it up...jets, needle, accererator pump nozzle. Normally Mikunis come too rich everywhere except the main jet. Stock pilot jet is 25, needle is 97, pump nozzle is 70 and main jet is 160. Most folks end up with a 17.5 or 20 pilot, 98 needle, 50 pump nozzle and 165 main. Youshould download the tuning manual from Mikuni's website.
pfffool
EVO
24
04-13-2023 08:47 PM
oldyeller
12-24-2009 03:00 PM
csd4682
Ironhead
05-24-2008 11:12 AM
jonny ebola
11-07-2007 08:18 PM
Garett
04-09-2007 04:26 PM
Quick Reply: cold and jetting probs?
