Anyone installed a set of these? It doesn't look like the bracket that mounts to the tranny will fit the lower nut, any experienced folks out there? I have enough beer, I mean what could be the problem.
Saylor I have put a ton of those pipes on post a pic.......or explain it to me...Im not following you, they should fit no problem, I dont think they really need a bracket on the exit end, cause they are so short they just support off the head bolts.
Ok then, riddle me this, the bracket that affixes to the tranny needs to have the lower right hand bolt on the tranny backed out, but it also appears that the transmission cover that protrudes won't allow the bracket to properly align with the bolt hole.Also, the line that exits right in front of that bolt, can it be removed w/out issue during this process? Excuse my ignorance, but I've found that if you ask first it makes the rest of the day go alot better.
And, I forgot to mention that my bike has a trickshift 6 speed and the tranny cover is much thicker than a 5speed. making the mount points on the bracket difficult at best to attach
