Big City Thunder baffles: HOLY MOLY LOUD!!!!!
Just for stupid giggles, I bought a set of Big City Thunder monster Baffles. Last night I bolted them in. Very simple to install, however B/C recommends a specific 3" minimuminstalled length from the end of your pipe so you will most likely need to drill an additional5/16" hole in your pipe. I needed the 2" baffles for my V&H straight shot HS pipes.So for the moment of truth, I lite my bike off, and I swear to god, I thought I was hearing a 124" hot bike right out of Orange County !!!! These things are so deep, and so loud, you swear you have straight pipes without that annoying top end nasty open dragpipe sound. The B/C baffles are about 6" long, and are stepshaped like an hour glass. The also use a neat smallround restrictor welded inside the baffle that resembles a 3/8" flat washer . This must create the needed backpressure to keep the valves cool, and maintain good exhaust scavenging. These B/C baffles are almost too loud, but I must admit, I absolutely LOVED the tone. I am not a WOT gear bangin' pilot so I probably will leave the baffles in. As far as enginerunning, my bike seems to run exactly the same as it did with the stock V&H HS baffles.
_Clam
_Clam
RE: Big City Thunder baffles: HOLY MOLY LOUD!!!!!
The 3/8 washer is nothing more than a variation of the lollipop trick that people have been using for decades. The BC baffles are little more than a 5 buck baffle with a lollipop in them. I feel certain that this is the reason BCT doesn't give you much of a look at them on their website. They realize that people will see them for what they are (or aren't) and just fab up their own.
I needed some more back pressure when adding Duals. I made some 1" lollipops and put them in the headpipes just in front of my baffled mufflers.
[IMG]local://upfiles/17633/E5294A28658F4BB182EC644E87AD3999.jpg[/IMG]
ORIGINAL: F117ewo
The BCT solution is a bit low tech, but it works. For those of us without a torch in the garage to fab up the baffles, it works plenty good. That said, they are still pretty pricey items, but I like mine a lot.
Jake
Jake
