loose muffler
Old 05-10-2014, 07:41 PM
EdandGrace's Avatar
EdandGrace
EdandGrace is offline
Default loose muffler
Recently installed S&S SPO mufflers on Rush True Dual head pipes. After a couple hundred miles I noticed the right muffler was loose. Clamp was tight but muffler would move back and forth. Loosened the clamp, moved it a little and was able to tighten it up. Couple hundred miles later and muffler is a little loose again. Suggestions? New clamp? Thanks.
Old 05-10-2014, 07:47 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,935 Likes on 19,376 Posts
It's recommended that you use a new clamp ( although many get away without it ) when installing new mufflers. I had a similar situation on my 2009 FLHTCU. Be sure to "fully engage" the muffler on the head pipe, and a block of wood and a gently love tap on the end of the muffler to ensure that it is all the was=y will help.
MiniWolf
08-17-2012 07:12 AM
sportyslr
06-19-2011 07:57 PM
odie-in-az
07-27-2010 02:29 PM
Gary7
12-12-2008 07:06 PM
bub2007
10-09-2007 09:01 PM
Quick Reply: loose muffler
