big shots long...HELP!
Old 03-26-2007 | 05:51 PM
jfdAML's Avatar
jfdAML
1st Gear
Default big shots long...HELP!
OK...so what's the chance that V&H sent the wrong parts? i can not fit the new pipes into place. Can't fit pipes around the motor. Holding bracket doesn't seem to line up with anything. Do i have the wrong parts or am i doing something wrong?????
2006 Softail Deluxe
V&H Big Shots Long
Old 03-26-2007 | 06:37 PM
Steeltown's Avatar
Steeltown
Default RE: big shots long...HELP!
Go to their website and match up your bike with their product number, and make sure you have it right....there should not be a problem getting them around the engine at all.....I installed them on a night train I had a couple of years ago
Old 03-26-2007 | 11:37 PM
Rhubarb's Avatar
Rhubarb
They are easy to fit, but you do have to maneuver them a bit.
If you attached them to the frame already, then there is a problem. I have had them off/on a couple times with no issue at all.
Did you take off your floorboard and the passenger peg?
Old 03-27-2007 | 09:15 AM
jfdAML's Avatar
jfdAML
1st Gear
Yes...i have floor board and rear peg off. i can get the rear pipe onto the exhaust port, but the front doesn't seem to want to get around the engine. i spoke to V&H support yesterday, and he told me that it should be a snug fit to get the pipe around the fin. He ssaid i will have to give it a tug and work it around. Being sure to wrap up the new pipes so as not to scratch them, of course!
Going to try again tonight.
Old 03-28-2007 | 01:21 AM
Rhubarb's Avatar
Rhubarb
Yup... just when you think it's not going to fit... bam its in there.
Be careful to not scratch the fins on your motor either.
Old 03-31-2007 | 08:46 AM
Luke611's Avatar
Luke611
2nd Gear
Mine were a tight fit too. Rhubarb's got it right, watch the engine fins. I ended up with a few scratches on mine.
burnsy87
02-28-2014 07:55 PM
wiguy
07-19-2013 03:49 AM
tully_mars
Fuel Moto / Jackpot Mufflers
12-16-2011 02:16 PM
jlasoftail
04-30-2010 11:38 AM
hdtaggs
05-10-2009 09:47 AM
Quick Reply: big shots long...HELP!
