Need advise on Night Rider Fuel enricher
Old 03-20-2014 | 09:09 PM
Sangam13's Avatar
Sangam13
6th Gear
Default Need advise on Night Rider Fuel enricher
Hello Brothers,
I have a Heritage Softail 2013 (103) and I removed the baffles and catlyictic converter from the stock exhausts, installed SE Stage 1, installed NightRider fuel enricher (XiED) and also installed Thunder Torque inserts W158 (sold by DK Customs).
The sound of the bike is awesome, heating has reduced greatly but I can feel that the bike is dragging and I lose power/torque in the 3rd and 4th gears at 2000-2400 RPM.
Do I have to replace the Spark plugs ?
Any advise will be welcome as the local dealer has no clue and will not advise.
Old 03-21-2014 | 07:59 AM
nhrider1's Avatar
nhrider1
Originally Posted by Sangam13
Hello Brothers,
Problem probably lies with the XiEDS. They increase the fuel across the entire range. Works OK in some cases, but can't compensate for variable fuel requirements under all conditions.
You'd be better off with a real tuner that allows you to map for different rpm and load requirements.
Old 03-21-2014 | 11:02 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
The problem is NOT the XiED's. The ECM still works and compensates for conditions with the XiED's installed.
Acceleration at 2000-2400 rpm in 3rd and 4th gears is too low of an RPM. That is lugging the bike. It is NOT meant/designed to ride/accelerate at those RPM's in those gears. Doing so with any configuration puts excessive stress on the crank.
With a free flowing air cleaner you will have more power down there, but it is Still Not a good ideas to accelerate in 3rd gear or higher at anything below 2700-2800 RPM.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 03-21-2014 | 11:14 AM
Sangam13's Avatar
Sangam13
6th Gear
Thank you for the posts. What should be the ideal RPM for 2nd, 3rd and 4th Gears ?
Also, by bike does not lug - I feel that it starts missing when I accelerate and I feel that momentarily I lose the power before I move to a higher gear.
Your advice is welcome.
Old 03-25-2014 | 01:15 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
In second, mild acceleration, I would not be concerned with a low RPM of 2200.
For 3rd & 4th, ideally you want to be 2500 or higher. For moderate to strong acceleration I want to be above 2800 RPM. To cruise (very little throttle...maybe 4-6%) then you're probably not doing any damage between 2100 and 2500 RPM.
The Twin Cam 96 and 103 are stroker engines and like to be at higher RPM than the TC 88.
The HD single crankpin 45 degree design, especially a stroker, will have extra stress on the connecting rods and crank under a load at low RPM.
I am not understanding what you mean here-
T Man
08-13-2017 06:26 AM
08Nighttrain
06-12-2017 11:01 AM
rogersachs
12-12-2013 03:27 AM
milfly
07-12-2010 07:14 PM
quackattack
10-30-2009 07:46 PM
