Pop, Heat and Slip-ons Only on FI
Hey All,
I have a 2006 Softail Fuel Injected which had the injector upgrade from the 8* injectors.
I put on SE II Slip-ons no other mods.
Bike runs fantastic and only pops on decel (not all of the time). Heat is pushing 230-250(analog dipstick)in 65* weather.
How much pop and heat would be consider safe before I consider adding fuel management?
Thanks,
Dragonsoni
Thanks,
Dragonsoni
RE: Pop, Heat and Slip-ons Only on FI
In 65* weather with temps in the 230-250- range, you could use some fuel management there to cool things off a bit. It sounds like you have just the upgraded download for the 25* injectors and no other download added. You'll also run much better with some more fuel and may consider the stage 1 intake addition to give you better breathing. You' will not regret it.
benscratchin
Exhaust System Topics
03-08-2017 05:22 PM
ezriderpgh
03-10-2009 10:17 PM
