96 to 103
96 to 103
well guys here is my question.
ive got a 2009 night train with a 96ci. ive got the big radius 2/2 with a s/e heavy breather and se 204 cam. now its fun, lots better then stock but lets face it I want more. been thinking about going to a 103. if I do that im going to use the high lift rockers. also thinking about using the cnc ported se heads.
what do you guys think? is the 103 worth it? the heads?
Usually those pipes need the baffles modified when looking for more power, but they do seem to work.
Scott
If you go 103" or 107" and headwork, those cams are going to be really "out of place" - you can pick a bigger cam that "hits" in the same rpms but will do the BB and headwork justice.
It would have a boat-load of low-mid range power, and with a good flowing cylinder head, it would/could make surprising hp as well.
As our web site states, we can/do usually work with a clients pre-existing parts to help achieve the goals.
Scott
Y pipe or not?
I don't know what to do on my build. I need to get it dynoes but went to fullsac dual kit, the 200 dollar kit but after researching and not wanting to spend money on a 2 into 1, Thought of putting a plug in the y pipe to make that a 2 into 1 but people say one pipe is shorter so that's not good. so what can you gurus tell me, Make my pipes 2 into 1 or just leave the y pipe alone. What will give me the most HP? I will cut the restriction out of the y pipe. I heard that's good for 2 to 4 HP and that is hard to believe but will cut it out anyway.
Find a porter/builder; two forum sponsors have replied to your post. Work with the porter; the guys that do this for a living. Establish a budget, know how you ride and where you want the power and let the porter/builder tell you how to achieve the goal. Do not rely on input from forum members for anything other than anecdotal data that may or may not fit your application.
The only thing I wil suggest is that you 86 the BR pipes; not a performance exhaust.
