fuel moto IC cylinder pros and cons.
Here is a picture of a FM IC cylinder with a CP 107FT 3.937" piston in the bore, if you have any additional questions you are welcome to contact me
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Just looking at the top of that cylinder it appears it will also have enough meat in the machined aluminum for the water cooled heads. You wouldn't happen to have a pic with a water cooled gasket on the cylinder? That thing does have a seriously thick liner, do you clearance the bore to piston differently for this application with the CP piston?
Must be the same/same cylinder casting that MTC manufactures in 4 1/8" bore, and they just leave more material in the bore prior to them finishing it for you, and then they just simply turn the spigot O.D. for the 107" to fit in the un-bored cases, would be the only reason for the piston jet scallop in that 3.937" hole.............
MTC does not build a Harley casting and they have absolutely nothing to do with our IC cylinders, also note the sleeves are completely different between our 3.937 and 4.125 cylinders. While I appreciate your concern, it is clear what you are trying to do here. As I noted earlier, if you have any questions on our products or how we do things you are welcome to contact us at 877-729-4754
I had a response all typed in regards to an episode that occured with Green Filter not so very long ago........but I won't air that out on a public forum........
Carry on.....
Could you send me a picture of your engine. I would like to see what the IC heads looks like on a engine. Thanks
