S&S Easy start cams
Old 01-16-2014 | 09:16 PM
Brick0044's Avatar
Brick0044
Default S&S Easy start cams
A friend wants to sell a set of S&S 570 Easy Start cams they are chain drive part number 106-4958 is the rear and 106-4957 is the front. Can anyone tell me if they will work on an 09 FLHX. I can't seem to find those part numbers anywhere on the net. He says the are for 2007 and up touring, but I want to be sure.
Old 01-17-2014 | 07:48 AM
prodrag1320's Avatar
prodrag1320
not a good S&S part #.easiest way to tell is to measure the side of the cams that go to the inside (opposite in the sprocket),99-06 will be .875",07-up will be 1.0"
Old 01-17-2014 | 08:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
As Kirby has said, the inner cam bearing journal will measure 1.000", for use in a late model.
That cam needs to set at 10.0 cr to be effective also.
Scott
Old 01-19-2014 | 08:21 AM
Brick0044's Avatar
Brick0044
Thanks guys I will measure them to see. Here are some pictures of the cams in the boxes and I opened them to see that they have the same part number on the end of the cam and they did.
Attached Thumbnails S&S Easy start cams-20140119_071535.jpg   S&S Easy start cams-20140119_071541.jpg
Hillsidecycle.com
Milwaukee Eight (M8)
01-01-2017 03:49 AM
harleytq
07-14-2016 01:20 PM
BKBIGGZ
Engine Mechanical Topics
08-25-2015 05:57 PM
toxic donkey
09-26-2012 06:56 AM
Kaycee
12-29-2011 01:40 AM
