Front Cyl always richer- 2011 Sportster
Old 12-01-2013 | 06:42 AM
awilson40's Avatar
awilson40
Veteran: Marine Corp
Default Front Cyl always richer- 2011 Sportster
Hi Gang,
I have a 2011 Forty-eight with mods listed in my sig. A little History: In stock trim the bike had bad light throttle surging and worse after the mods. IED's helped but didnt totally eliminate it so I went with FuelMoto's Micro EFI eliminating the O2 Sensors and it runs much better. I have been trying different canned tunes. One thing I have noticed on Every canned tune is that the rear cyl seems fine on exhaust pipe color and plug color but the Front Cyl is very rich. I have checked and double checked for any intake or exhaust leaks on Front and rear and none are found. Right now I have a really good Map from Fuel Moto that the bike runs best on, MPG is down 2-3 mpg and the Front Cyl is noticeably richer. After 50 - 60 miles the exhaust tip is Black on the front, with just a slight residue on the rear.
To equal the two Exhaust and Plugs I end up pulling about 8-10% of fuel from the Front Cyl.
Any Thoughts or Comments ??
Thanks
Old 12-02-2013 | 07:13 AM
awilson40's Avatar
awilson40
Question on Tuning approach.
If it seems my front cyl is always richer, no matter what map I try, Should I take the best Map and pull 5% or so across the whole table to start ?
Thanks
Old 12-02-2013 | 01:04 PM
BadBagger08's Avatar
BadBagger08
The front cylinder usually takes more fuel on most of the maps that I have made or seen with my auto tune.
You could take some out of the front cylinder. Ride it and see how it goes. if you get any popping keep a eye on the RPM's and the throttle positioning so that you can increase the fuel in that area of the map. I used a zip tie on the grip and then marked the housing wide open, 1/2 way and so on to help.
Save the original settings to a excel file so you can easily go back if you want to.
Old 12-02-2013 | 01:31 PM
awilson40's Avatar
awilson40
Great tips! Thanks a lot.
gearheadfmc
11
05-06-2021 04:35 PM
uberbania
07-12-2018 04:00 PM
dlporter
03-29-2016 11:40 PM
dboyd
03-08-2012 08:46 PM
zzmellio
05-20-2007 09:06 AM
Quick Reply: Front Cyl always richer- 2011 Sportster
