Evo - Lifter & Pushrod Advice Needed.
Hi;
I have a 1996 FXSTC with the 1340cc Evo motor.
The motor has 10.5 comp. forged pistons, Woods 8 camp, high performance valves/springs, heads have been ported and polished along with the other mods needed to run right, carb massage, electrinics etc...
My bike was making clacking sounds so I pulled the pusshrods and lifters and discovered the very front lifter with a loose roller, the next one behing it was slightly loose side to side but that is all.
*My Lifters are: JIMS - Poer Glide Big Axle, Part #2456-1 , Should I replace these with the same exact ones for $91.00 a piece? Are there any other Lifters that can handle this engine for less money?
*My Pushrods are:RevTech - Adjustables - I could not read the first two numbers clearly but the Part # appears to be: 00-59227
Are these pushrods good enough to stick with or should I change these out? I am interested in the Quick install pushrods but, need some advice on which brand to use. Thank you for all your experience and Free Advice!! Bo
http://gaterman.com/GMC%20Website/Ga...ure%202010.pdf
There are a few dealers on this and other sites that sell them.
I have no experience with RevTech adjustables. I've always liked Rivera Taper Lites in my Evos.
