You are sorta correct. In the long run even .004 will take out the pinion bushing but only after a loooong time. Most will not put on the miles to see this happen though. Welding, truing, and pluging the crank would only be like $900. If you dont ride that much than dont worry about the crank if its not that bad.
Well, I do put miles on. 14K+ since I got it in November. I probably wont put *that* much on in the next 12 months, but I bet I get to 10K anyway. I ride my bike.
Im talkin like 75-150k. Dont think it would be an issue for you then.
Not to high jack or anything, but since we are also talking about the crank.................
once split should I upgrade the oil spigot or anything else while I'm getting it trued, welded, and left bearing installed(no timkin to much $$$$)?
The stock 07 pump and plate should be ample. Its when you have to replace it that the SE version becomes more affordable. Id throw a lefty bearing in both sides while I was in there. Of course replacing any bearings while your in there if its a B motor.
That's what I though. I'm going to get the lefty bearing installed, plug welded, & crank trued......all for peace of mind cause I do like to crank the throttle quite a bit(WTF is the point of doing all these upgrades if you don't LOL!).
If I wanted to go for a nice Sunday drive I'd take my car.
Right - I meant 14K *per year*. You know someone who puts 150K/year on a bike? Heck, I dont know anyone that puts more than 14K/year on, at least nobody that isnt retired!
its not the amount of miles,its how its ridden.if you ride fairly normal,a lower end most likely wont move in 1000 or a 150,000.if your doing holeshots & crap,it could move in 1 mile
